Autocad layout tools missing
fprico
Message 1 of 20
fprico
Hi, I have recently download Autocad 2016, but the layout tools for creating 2d views is missing.
Replies (19)
Message 2 of 20
natasha.l
Hello @fprico,
Welcome. Smiley Happy
It seems like you may just need to add it. You can add the view panel by right-clicking on the empty space to the right and selecting "Show Panel" > "Views"
Keep us posted on the progress.
Message 3 of 20
fprico
Thanks, I attached an image to see what is missing.
Message 4 of 20
Darin.Green
@fprico
You have to be in a layout tab in order to see that tab.
If this information was helpful, please consider using the Accept Solution
Message 5 of 20
natasha.l
Hello @fprico,
I have an article here that shows how to Add a new toolbar button. I just went through it now myself. Navigate to the top of the toolbar on the "Manage" tab click "CUI" icon search & drag the "Layout" to the "Quick Toolbar" in the top section. It should appear after you close out the window.
Hope this helped. I will move this over to the AutoCAD 2017 forum for more input.
Message 6 of 20
fprico
I could not find that, could you post an image?.
Message 7 of 20
natasha.l
Hello @fprico,
Sure, here you go.
Message 8 of 20
john.vellek
Hi @fprico,
Try typing in CUI, select Layouts from the Toolbars category and on the right select Add to workspaces in the Default Display
John Vellek
Message 9 of 20
fprico
I just change to "add to workspace" and it doesnt show it, the version Autocad LT 2016.
Message 10 of 20
john.vellek
Hi @fprico
Did you also click on a layout tab first? You have to be in an existing layout in order to see it at the top of your screen.
John Vellek
Message 11 of 20
fprico
Hi, yes this is how it looks.
Message 12 of 20
Vinayv4v
Try to move the file to the ribbon tab (not in toolbar) in the CUI and then check if the tools are there.
Thanks & Best Regards
Cheers,
Vinay Vijayakumaran
Message 13 of 20
pendean
Community Legend
Community Legend
Right-click in that red-zone: are all the panels turned on?
If not, it's time to reset autocad https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Message 14 of 20
fprico
Hi, just reset setting to default and nothing. The show panels looks differnt.
Message 15 of 20
fprico
Hi, just reset setting to default and nothing. The show panels looks different.
Message 16 of 20
john.vellek
HI @fprico,
Can you use the Windows Snipping Tool to try and capture what that Show Panels looks like?
It might be worth Resetting your CUI as well per the instructions in this article.
John Vellek
Message 17 of 20
In show panels I can see only two options layout and layout viewports. tried resetting and re install Nothin happen, what to do please
john.vellek has embedded your image(s) for clarity
Message 18 of 20
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Do you see the Layout tab if you click onto a layout (paperspace)?
John Vellek
Message 19 of 20
dehodges
How did this not get resolved.  I have the exact same issue and I cannot find a solution anywhere.  I can't add a legend, scale, north arrow, or anything.  Where are all of the Layout tools??
Message 20 of 20
pendean
Community Legend
Community Legend
Did you do as asked in the post you are replying to?
If yes, are you sure you actually are in a layout?
what does ABOUT command say about your version?
Could this be your issue https://forums.autodesk.com/t5/autocad-forum/layout-tools-tab-not-showing-in-ribbon/td-p/8372469
Or this perhaps https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Cannot-s...
TIA
