Anuncios
AutoCAD - Layers in model space don't appear in the viewport
No aplicable
A couple of layers in model space don't appear in a new viewport. The layers are turned on, thawed, and unlocked. The layers were copied in from another AutoCAD file. I've checked the file the layers were copied from and they are on, thawed and unlocked in that file as well.
Please help!
[ The subject line of this post has been edited to include the product name by @handjonathan ]
0 Me gusta
Responder
Soluciones aceptadas (2)
35.932 Vistas
27 Respuestas
Respuestas (27)
ziyiyang1994
Community Visitor
Community Visitor
Very helpful
0 Me gusta
3Oaks
Community Visitor
Community Visitor
Hi all!  I did not see the solution posted, but for me, here is the simple fix when this happens:
Select the viewport where layers do not appear.
in the command line type "ANNOALLVISIBLE"
If this is set to "0" change it to "1"
That should fix things.
Good luck!
0 Me gusta
3Oaks
Community Visitor
Community Visitor
I posted this in a reply somewhere in the thread, but just in case...
When this happens to me, the quick fix is:
1) Select the Viewport in question in your layout. Do not double-click inside it, just select it.
2) In the command line, type "ANNOALLVISIBLE"
3) IF this is set to "0" change it to "1" (Type 1, hit Enter)
That should fix it! Good luck.
0 Me gusta
elliehays
Thank you! This solved my problem.
mandytluo
Community Visitor
Community Visitor
Thanks. I ran into the same issue. problem solved!
khouston6B7AC
Go to the layer you are having issues with in the layer properties panel. Right click the affected layer, then select "restore layer state" from the dropdown menue.
0 Me gusta
kellyHPGN7
Community Visitor
Community Visitor
This was immensely helpful.
Thank you for taking the time to post this!
0 Me gusta
patrikd
Community Visitor
Community Visitor
Thanks! This is the real solution
