AutoCAD - Layer Question
Matt.WoodU87JC
Message 1 of 12
Matt.WoodU87JC
I am new to AutoCad and have a question.  I have an existing DWG that contains 3 convention halls.  I have been asked to put each of the 3 halls in its own layer in order to import them into ungerboeck.  I highlight the first hall and put that into its own layer with out any issue and can freeze it to remove the other halls.  When I try to put Halls A-C into a layer it does not work.  The DWG only has 12 layers including Hall A, B and C that I created. Is there a way to hide entire portions of drawings in CAD and keep them in layers?
Appreciate anyone's input on this.
Thank you,
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
What does "...into a layer it does not work..." mean please? We can't see your screen and have no record of your actions/results here.
Message 3 of 12
imadHabash
Hi and Welcome to AutoCAD Forum,
I think that we still need more clarification for your issue .. we didn't catch your needs !! I don't know if MAXSORT System Variable will make different with you .
Imad Habash
Message 4 of 12
Matt.WoodU87JC
Thank you for your response, I will try to clarify this better by doing a screen record as I think this would really help, I just have to get IT to allow this on my computer.  I think the easiest way to explain this is I am trying to put multiple portions of a DWG into 3 separate layers. I will post some video or photos as soon as I can in order to help you understand what I am trying to do. I appreciate the forums help and will get you more info soon.
Thank you for your help and patience on this.
Message 5 of 12
Matt.WoodU87JC
Attached is a video to hopefully explain the layers issue, I am trying to isolate Hall A, in one layer, Hall B in a 2nd layer and Hall C in a 3rd layer.  I am not sure I can do this, as you see in the beginning of the video I can freeze layer A and it just shows Hall A, but then when I try to isolate Hall B in the second half of the video when I then try to freeze Hall A it shows hall A & C but I can successfully isolate Hall B. Thanks again for all your input!
Message 6 of 12
Patchy
Draw 1 rectangle around each "Hall" so it shows better which is which.
Is this hall "A"  or everything right of it is hall "A" ? Maybe the freeze command is using for the wrong hall.
Message 7 of 12
Matt.WoodU87JC
Thank you for your help, This video shows Hall A, B and C.  In the first portion of the video you can see I freeze the layer A and it only shows hall A, then I try to remove Hall A and C to only show Hall B when I freeze Hall B and  this works but then when I go back to freeze Hall A it now has Hall A and C...  I want to be able to put each hall in a layer so it only shows Hall A in 1 layer, Hall B in a 2nd layer and Hall C in a 3rd layer, is this possible?
Thank you everyone for you help on this.
Message 8 of 12
Kent1Cooper
@Matt.WoodU87JC wrote:
.... I can freeze layer A and it just shows Hall A ....
Don't you have it backwards?  Freezing a Layer is the opposite of isolating it that it looks like you want to do, and makes it invisible and ignorable by AutoCAD [i.e. even "more invisible" than just turning it Off].  If you want to show Hall A, don't you want to freeze all Layers except Hall A?
Kent Cooper, AIA
Message 9 of 12
imadHabash
Of course you can put each portion on a certain layer .. BUT I think that it's good to give some hints that may help:
  • Isolating layers ( Layiso) totally different from isolate command (isolateobjects ) .
  • I assure you that something is wrong in your working procedure and understanding commands details and the way how it's work .
  • As an architect .. putting those portions on a certain layers NOT the right way for working .. If your need is a must , then you have to try attaching those portions as an xrefs . >> Click <<
Imad Habash
Message 10 of 12
Matt.WoodU87JC
Thank you all for your help on this!
Message 11 of 12
nislam04
Message 12 of 12
Kent1Cooper
Will LAYWALK do what you want?  Un-check the Restore on exit option.
Kent Cooper, AIA
