Announcements
AutoCAD layer preview
hnermin
hnermin
can I disable this option in AutoCAD 2012.
when I get over line it pops out this window, and I dont know how to disable it. 😞
john.vellek
Hi @hnermin,
I believe you are referring to a rollover tooltip. That feature can be toggled off in OPTIONS on the display tab
John Vellek
Vinayv4v
Since You have not highlighted which one to turn off,
1) As per @john.vellek suggestion if you need to hide the tool box then you need to make ROLLOVERTIPS <0>
2) If your need to turn off the  Selection preview of the line then you need to make SELECTIONPREVIEW <0>
Cheers,
Vinay Vijayakumaran
john.vellek
Hi @hnermin,
I am checking back to see if my post or @Vinayv4v's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
