Autocad Lag on Cursors in commands and dragging objects.
jimmy0612
Observer Observer
Message 1 of 10
jimmy0612
Observer
Observer
Hi guys, i really need help help here. i having cursor lag problem when ever it is in model space. it lag on all the commands especially moving and stretching objects. i facing this issue when i using ACAD 2020, then i upgraded to 2022 also facing same issue. i even tried all the solutions on internet as below:
1. DX12 to DX11
2. turn off hardware acceleration
3. update graphic card driver
4. reinstall software and install all updates
5. Upgraded hardware like motherboard, graphic card and ram
6. Reset entire PC
After reset the PC it works at the beginning, but after few months the problem came back.
i already tried all what i can get from internet but still not getting fixed. i have 2 pc with similar setting and one laptop which facing lower specs, but only this PC having this issue when working with same files.
Anyone can help!?
My PC build as below
Processor : Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
Ram: 64GB DDR4 3200
Graphic Card: Gigabyte Nvidia GeForce GTX 1660 6GB
Replies (9)
Message 2 of 10
imadHabash
  • Ensure that there is NO tool connected to your PC? If there is any,disconnecte it and restart your PC.
  • Does this issue happened in all CAD drawings?
Imad Habash
Message 3 of 10
paullimapa
Did you follow the different steps on setting 2020 vs 2022 to use Directx11?
Enter GraphicsConfig command do a screenshot and share this here
Also enter About command again do a screenshot and share this here as well.
Have you tired installing latest 2025.1.1 to see if this will workout on your system?
Paul Li
IT Specialist
@The Office
Message 5 of 10
jimmy0612
Observer
Observer
Appreciate for your kind reply, i will try that! Thanks!
Message 6 of 10
jimmy0612
Observer
Observer
now i am using 2023 and still having the same problem... really not sure what happening now..
Message 7 of 10
pendean
Community Legend
Community Legend
Not seeing anything like that over here in our offices. Sorry.
Have you installed the 2023.1.6 Update yet? ABOUT command in your AutoCAD will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards please.
If that did not help... You could try setting GFXDX12 variable to 0 (that's a zero): a restart of your AutoCAD2023 is required for it to take effect.
Also consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, start a support ticket through your subscription portal as explained here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
Message 8 of 10
jimmy0612
Observer
Observer
yes, all drawings have the same issues. what tools do you mean? mouse and keyboard?
Message 9 of 10
jimmy0612
Observer
Observer
GFXDX12=0 and graphicsconfig no use as i mentioned in the post above. and i dont think the acad up is the issue here cos i have 2 pc and one laptop using same thing same version, only this pc have this problem. but i have upgraded some hardware i.e mother board, ram and graphic also no use. just left processor i not yet upgrade because i need to confirm diagnose the cause of issue before spending more.
Message 10 of 10
pendean
Community Legend
Community Legend
@jimmy0612 wrote:
...cos i have 2 pc and one laptop using same thing same version, only this pc have this problem....
You could try https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
You need to... open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
