Anuncios
AutoCAD issue
AutoCAD issue
No aplicable
I used AutoCAD 2013, but when I tried to open AutoCAD files, it will be poped up windows and display "Educational Version-PlotStamp Detected"message, you can check attachment, could you tell me why this happened? because I can use it normally before.
I had contacted our IT and help me to reinstall AutoCAD 2013, but this message still exist.
my contact :+86 513 83392082
0 Me gusta
Responder
386 Vistas
3 Respuestas
Respuestas (3)
No aplicable
Is you company or the other working parties using Educational Version of AutoCAD?
Your drawing seems come from China as the drawing file using chinese name "包裝區域佈局......"
0 Me gusta
martti.halminen
That is a slightly older Autocad working as designed. The problem is not in the program, it is in the data: the drawing has been made with an Educational version (or somebody has copied something from an Edu .dwg into that).
You'll find plenty of additional explanations by searching for the Educational stamp in this forum.
Nowadays the easiest way to remove the stamp is opening and re-saving the drawing with a sufficiently new version of AutoCAD or DWG TrueView (2016 or newer, IIRC).
0 Me gusta
Alfred.NESWADBA
agreed to @Anonymous, parts of this drawing are created by AutoCAD education licenses, so you are not allowed to use such drawings for commercial purposes.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
