Autocad, issue with cutting a hole, using presspull
Message 1 of 9
So, I am trying to cut in the building 2 holes, using presspull command, from a drawn rectangle, adiacent to the wall I want to cut. Do not know why, but it extrudes instead of making a hole I have tried with substract and also tried to use explode (this one removes textures of the extrusion). If anyone can help me would be very appreciated I am struggling for a few hours, but the problem still persists and its very annoying.
Replies (8)
Message 2 of 9
Alfred.NESWADBA
can you please upload the dwg-file?
I would first check if the polyline is really exact on that wall, I would also try to first set the UCS manually to the wall and then start _PRESSPULL or _EXTRUDE and then using _SUBTRACT.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
here it is
Message 4 of 9
I had the same problem, when I tried to, resize a wall for the windows to fit, so I did it more barbaric, by exploding all the textures and remaking the whole wall with extrude with, with small extruded lines to fit the window...
Message 5 of 9
Alfred.NESWADBA
your wall is not a solid, these are 2 objects of type "Region" ... to use _SUBTRACT or _PRESSPULL and get the new object subtracted from an existing object the existing object has to be of type "3D-Solid"
Recreate that wall as 3D-Solid, then all will work well! 😉
Also take care with your wall, there are a lot created as region and as surface, sometimes region AND solids for just one side of the wall, you might run into troubles with that structure.
- alfred -
Alfred NESWADBA
Message 6 of 9
I tried to modify all of them to surfaces but it seems the problem still persists, I don't really want to recreate all from scratch
Message 7 of 9
Alfred.NESWADBA
No, you should create 3D-Solids for your walls, not surfaces.
- alfred -
Alfred NESWADBA
Message 8 of 9
Remade the wall from parts, dunno why but if I try with polyline to draw a singer figure and extrude, it doesn't let me, I tried also converting them to 3d objects, still doesn't work... only to surfaces... Do you have any advice how can I do them maybe without splitting them into so many small figures, to create a bigger one, like how can I convert or redraw the wall without using so many small figures to assamble them into a bigger figure?
Message 9 of 9
Alfred.NESWADBA
In your screenshot I can see that your wall is not just one 3D-Solid, but it again contains surfaces:
Also it does not make sense to split a wall into single peaces (as you seem to have according to your screenshot)
Please find this short video to see how to
  • remove the existing vertical regions
  • create one wall from the top region (you need then to use _SUBTRACT to open the wall for the doors)
  • close the polyline you want to make a hole in the wall (it is not closed)
  • then extrude this polyline
  • then _SUBTRACT that polyline from the wall
- alfred -
Alfred NESWADBA
