autocad is frozen with the new changement
How can i use autocad now? Everything is frozen...i can't do anything! How come?
ennujozlagam
hello, have you try to install latest updates from autodesk? or GRAPHICSCONFIG try to turn off "Full Shadow Display" . thanks
Alfred.NESWADBA
Can you please describe more detailed what happens exactly?
Does "everything is frozen" mean you start AutoCAD and your computer is frozen? Or you started AutoCAD, created a new drawing, work some time on it and then AutoCAD gets slower and slower? ... or what between these 2 variants?
Also needed:
  • is this a new installation or was it already working?
  • if new install: did you install it as admin with disabled antivirus?
  • if not new installation: what changed on your system?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
