Autocad is crash at the start
No aplicable
I just installed Autocad 2016 and its crash at the start with the following masseges:
0 Me gusta
Responder
Soluciones aceptadas (2)
639 Vistas
7 Respuestas
Respuestas (7)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I believe this failure to start is because of your graphics card. Please start AutoCAD with the No Hardware switch and post back with your results.
John Vellek
0 Me gusta
No aplicable
How can I do that?
0 Me gusta
john.vellek
HI @Anonymous,
I included the link in my last post. Click on the "No Hardware" and it will take you to the article that describes the process.
Please post back with your results.
John Vellek
0 Me gusta
No aplicable
I am sorry, but I do not understand what to do..
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
I'm sorry. Let's try to fix it this way.
Do you see the AutoCAD icon on your desktop?
  • Right click on it and select Properties from the menu.
  • In the properties window, locate the Shortcut tab and click on it.Capture.PNG
  • Now, towards the top there is a field called Target. If you click in that field and then move your cursor to the very end of the text.
  • Enter /nohardware with a space between it and the other text.
  • Click OK
Now you can try to open AutoCAD by clicking this icon to see if it fixes the issue.  Please let me know the results.
John Vellek
0 Me gusta
No aplicable
Thank you very much!! its working.. what did I changed? and how it will effecting my working with autocad?
but I dont know why I can't activate ..
I enter the code but it gives me error
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
I am glad that this worked! Note, I edited your post to remove the serial numbers. I suggest for getting the activation to work, that you either post a new question in the installation forum or contact Activation and Registration through your account page.
Turning off the hardware acceleration means that you will be able to see Point Clouds and such but if you are working primarily in a 2D environment then you shouldn't have any major issues. At some point, if you feel it is necessary you can update your graphics card to one that is certified to run with Hardware Acceleration.
John Vellek
0 Me gusta
