AutoCAD hangs after opening .DWG file, running windows 10.
I have had problems with AutoCAD running on my PC ever since I upgraded to windows 10. I have got a .DWG file to work once but every other time I try to open a .DWG file it loads the file and immediately freezes. Here are a few things I have done:
-I have done a reinstall of AutoCAD 2015 with all of its updates.
-Task Manager doesnt show (not responding).
-I have checked to see if there is another window behind the program awaiting a response. there is none.
-I have tried a handfull of different .DWG files, all have the same result.
-I have updated my VGA (which is a GTX 970).
-I have also installed SP1 and SP2. Nothing changed.
I have tried just opening the program with no file loaded and most of the interface doesnt respond to my mouse clicks including the top ribbon (home, save, etc), open file, getting started, recent documents and connect. The only things that work are the navigation tabs to go to the learn window and back. Also, I have been using Revit 2015 and have had 0 problems with that program through all of this.
It might be too much info but I rather get across all the info that might be useful to quickly get this fixed. I am at a lost with this one. I have pictures of the hanged progam and my computer specs. Any help will be mach appreciated. Thanks
