AutoCAD frezer while insert images JPG
Dear.
I'm having trouble inserting images jpg into my AutoCAD 2010.
When i I'II insert images JPG the CAD hangs does not respond. Smiley Sad
Alfred.NESWADBA
When exactly?
  • when starting the command (btw: which command did you use?)
  • when selecting a folder in the image selection dialog
  • when selecting a file in the image selection dialog
  • after you selected the image and pressed ok
Please try also to copy another JPG to a local folder and try the same with a new drawing ... just to know that issue does not depend on a specific drawing, not on a specific JPG and not on network connections
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
Hi and Welcome to AutoCAD Forum,
i suggest to install the Service Packs & Fixes for AutoCAD 2010 . >> Click <<
Imad Habash
I'm IT support. I don't know use AutoCAD. But i see the problem, the architect insert the image file with insert taskbar, not use command line. Now  the cad started work again Smiley Surprised
Alfred.NESWADBA
That did not answer any of my questions, even if a button was used to start the function ... you should see a dialog or did AutoCAD not show a dialog to select an image?
Also trying a new drawing with another image all in the local system will help us to isolate the problem.
Please understand that we can not see what you see, so we need a more detailed description of what's happening.
- alfred -
Alfred NESWADBA
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
It would be helpful to know if the AutoCAD installation has been fully patched and updated per Imad's suggestion.
It would also be helpful to understand the complexity and size of the drawing where this is occurring. Is it happening only in one unique file or all files?
Can you attach some sample files so I can see if I can duplicate on my computer too?
Perhaps this is a graphics card issue. Is the driver current?
John Vellek
@imadHabash.
I did the update the Service Pack's.
Unti now it did not present problems.
