Anuncios
AutoCad Freezing In All Versions 2015 -2019
javier.zavala
javier.zavala
Guys so I noticed in my job site Autocad keeps freezing when I open the program and close it multiple times. for example I open any version of Autocad and it works fine but after you close it and open it back up multiple times during the day it will freeze and a simple restart will fix the problem. but my question why does it do that? it happens to all of our machines which they all run windows 10 and there all fully updated. so what do I mean by freezing for example AutoCad still opens but when it opens I'm unbale to click on anything I can't even choose a new drawing. it's like if just froze. that's what I mean by freezing. is this normal?
0 Me gusta
Responder
Soluciones aceptadas (1)
453 Vistas
4 Respuestas
Respuestas (4)
pendean
Community Legend
Community Legend
If you unplug your PC/Laptop from the web/server (as a test) does the freezing stop?
0 Me gusta
javier.zavala
The freezing stops when I restart the P.C. and then everything goes back to normal. But I will try your solution next time it freezes, and I will disconnect from the web/server and see if it works that way too. Any thoughts why this happens? for testing purposes I actually restarted my computer and open up AutoCad 2018 and closed it a total of 4 times after the 5th time I noticed it froze.
0 Me gusta
pendean
Community Legend
Community Legend
Solución aceptada
I actually suspect you have a memory leak from all the program stops/restarts (more than one instance of AutoCAD still running in the background) but I want to make sure its not something tied to your network/internet access first.
Any reason you can't just leave the program up and running for the day? Close and open files instead.
What changed with your PCs or network or setup over the weekend when this started? You list old programs too so its not them.
0 Me gusta
javier.zavala
I think your right in the memory leak. that will make sense because our network is always running great. So I will accept the solution. And to answer your question about leaving AutoCad On That's What I tell all my AutoCad Users but I guess some people like to close and restart Autocad every chance they get for example bathroom break, lunch time, afternoon break etc... But I do tell them to leave it on just like you said.
0 Me gusta
