- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am using AutoCAD 2015 SP2 on Windows 10. I had a need to use the "dgnimport" command after receiving some .dgn files that needed to be converted to .dwg files. I used the command to create a new .dwg file from the .dgn file, and played around with the options, creating new .dwg files to see what changing the options would do. After I was done, I tried to use the command again, but when I typed in "dg" or "dgn" AutoCAD completely froze. I couldn't see my mouse while hovering in that window as well. I had to end task in the task manager. So after experimenting a bit, I discovered that if you just type "d", you can find the command in the long suggestions list. Also, if you type the command you want to use ("dgnimport" in my case) fast enough, you can avoid AutoCAD freezing. So it's something about typing "dg" or "dgn" slowly. If anyone has discovered this issue or has any suggestions, please let me know.
Thank you,
Matt
¡Resuelto! Ir a solución.
