Autocad Font size
Autocad Font size
Hi AutoCad Community!
I just want to ask if does anyone knows how to fix this problem? (please see picture below) the font size is way too big for the properties i just encountered this while studying autocad. I have already search different ways to fix this one but still it doesn't work. I have tried changing the DPI scaling and everything but still doesn't work I have seen a post about this one too in autocad 2015 and it seems there is still no solution for this. If someone knows please share your ideas. Thank you!
Alfred.NESWADBA
Hi.
AutoCAD 2017 Update 1 and Update 1.1 solves most of the issues.
If you run Autodesk Desktop App it will find the update for you so you can install that.
One additional info: for now this update is only available for subscription customers.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
For AutoCAD2017, go grab the 2017.1.1 update (notice the "point one point one" in the name) from your active subscription-only updates page https://manage.autodesk.com/cep/#products-services/updates
Read all about it here: http://blogs.autodesk.com/autocad/autocad-2017-fall-update/
Note: It doesn't solve all the problems, just many of them. A better fix will probably show up in AutoCAD2018 later this year or AutoCAD2019 next year.
But... AutoCAD2016 and lower were not designed for high-res monitors AND AUTODESK HAS NO PLANS TO EVER CHANGE THAT REALITY. These older versions will only run on displays set to 1920x1080 (also try 2560x1440 and up to 2560x1600 if you have that option) and at 100% text scaling (no more than 125% text scaling).
Read all about it here http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Odd-gra...
Thank you @pendean and @Alfred.NESWADBA I already updated my autocad but I cant to remember the version. There are no available updates for now my autocad version is just for 3 years does it mean that I cant download that update?
