autocad fatal error unhandled access violations reading 0x0020 at c6ca1008h
I got this error sometimes when I save a drawing for the first time. I searched for a solution in the forums but didn't find one. Thanks
Alfred.NESWADBA
Please let us know
  • which version of AutoCAD (exactly, use command _ABOUT and show us a screenshot)?
  • is that happening with a specific types of files or also new files?
  • are all files saved on a server or a NAS or local?
You might try:
  • to work with a different user account, to see if this depends on the AutoCAD profile
  • disable your antivirus (or that from the drive you are saving to)
  • run AutoCAD as administrator
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
There is no fix for "sometimes": so what is different or unusual when that happens? Dig deeper and find a common thread please.
This is the info that I have about the version of Autocad.
Autocad is running on a PC with windows 7, all files are running in the local hard drive. I have a master file that I use as a template. I am posting the version of Autocad that I have. The problem arrive, in random sessions, when I change from model view to layout. Thanks for your help.
cadffm
Perhaps offtopic: You running an old 2016 version, you should update your program!
Or why do you not update since 4 years?
http://download.autodesk.com/us/support/files/autocad_2016_service_pack_1/AutoCAD_2016_and_AutoCAD_L...
Check the current graphic driver and test older or newer drivers.
Sebastian
