Autocad extruded Polyline(closed) issue after extruding in 3rd party apps
I am new to autocad and I am attempting to make a part that will ultimately be laser cut. The issue I have is a polyline that I confirmed was closed. I have tried both extruding it and also press pulling it. Once extruded I am using the solid subtract function to make it a cutout from my solid. It looks fine in AutoCAD as well as Autocad viewer, however, third party applications show areas of the section as not removed. I have tried abviewer15 and it shows the same problem as sendcutsend.com does (which is where i need to ultimately send the part). I have tried saving it in multiple formats as well as redrawing it entirely. My first version and second version have slightly different results, but essentially the same problem. The polyline corners have a .1 filet radius, and I think this could be part of the problem though the error effect isn't direct from the radius. dwg and screen shots of the issue are attached. My impression is that a filet and extruded polyline are no longer closed and its bleeding out but i could be wrong about that. In addition to the poly line, the rectangle above it has the same issue but it might actually be part of the polyline coming through that as well. The rectangle was drawn as a rectangle with no filet so there really isn't any way that should be open or an issue.
