AutoCAD: Edit object attribute table automatically
I have several (many) objects in an AutoCAD drawing and each of them has the same attribute field in it's preferences. Now I would like to fill this attribute field with a number (object one - number 1, object two - number 2 and so on). Putting the numbers in manually is very time consuming, therefore I would like to ask you if there's an automated approach for this matter.
Thanks a lot in advance!
3wood
You can try ALTEXT which can assign a number to all attribute fields and then sort them in a certain sequence.
Perfect! Exactly what I needed. Thank you very much!
