AutoCAD Drawing appears empty
No aplicable
I have been working on a project for some time but today I tried to open it to complete and handed it to the professor but it did not open and only comes a black screen inside the application AutoCAD
untitled.pngI see like that , whats I do please help me to reset my product
@Anonymous,
john.vellek has edited your subject line for clarity: AutoCAD
0 Me gusta
Responder
2.336 Vistas
6 Respuestas
Respuestas (6)
ChicagoLooper
Type DRAWINGRECOVERY on command line. It will display the Drawing Recovery Manager which will list the available files that may help you recover what was lost after program or system failure.
Chicagolooper
0 Me gusta
imadHabash
>> .... but it did not open and only comes a black screen  <<
if you confirm that you already save your drawing with a special name . then the problem is where is your CAD elements ? please make sure that you open the right CAD drawing and from the right folder . if you're certainly sure try after opening to  ZOOM >> Extents  and see if any objects appeared . also yo can take a copy from the .Bak file for the same drawing and rename the extension .Bak to .Dwg .
Imad Habash
0 Me gusta
gotphish001
If zoom extents doesn't work as suggested maybe you added something way off to one side by accident. After you do a zoom extents, press Control + A. That will select everything on the screen. Do you see any blue grips? If you see a bunch on one side of the screen and a couple on the opposite side then one of those is something you probably put there by accident. Zoom in to one of them and see if it's your project. If it's something you don't need then delete it and zoom extents again. Make sure you unselect everything with ESC and then reselect the things to delete. You don't want to control+A and then delete and erase everything by accident either.
Nick DiPietro
Cad Manager/Monkey
0 Me gusta
BrianBenton
Can you share the file so we can look at it?
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
0 Me gusta
ara_neresesian
HI
in the drawing press ctrl+A and cheek the numbers on the properties box  Capture.PNG
 if its 0 thant mean you lost everything (try recover your BAK and autosave file)
but if it is more than 0 (depends to the your drawings ) you have to cheek zoom, layers off or on , layers freeze or,...
for better help  share your file with people in the forums
Good luck
jayhar
There are many ways to try and fix a file, here is the list, help yourselfhttps://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
0 Me gusta
