Autocad doesn't take commands
No aplicable
My autocad mixes up commands.
For example when I type in "m" for move it almost immediately changes to "offset" or when I type in "J" for for join it says "Unknown command 'VKV'. Press F1 for help".
When I change "PICKFIRST" to "1" (although it was still 1) and I restart the computer the issue is temporally solved until it starts all over again....
0 Me gusta
Responder
575 Vistas
6 Respuestas
Respuestas (6)
Alfred.NESWADBA
please start command _INPUTSEARCHOPTIONS and disable "Autocorrect" as well as "Enable Mid-string search" within "Enable AutoComplete" ... better?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
imadHabash
Usually this happened if there is outsource plug-ins or lisp already installed . for me ... i prefere to reset AutoCAD to default settings . >> Click >>
Imad Habash
0 Me gusta
No aplicable
Hi Alfred,
It was good until now...
When I type in "j" it says "unknown command" or when I type in "co" it changes to offset. Or when I select an object and type in move and hit enter, I'm asked to select objects.
Brigi
0 Me gusta
Alfred.NESWADBA
This can be an issue with the settings mentioned above (like _INPUTSEARCHOPTIONS) or a defect/incorrect ACAD.PGP file or a loaded app/plugin.
If you have not done too many customization then you can reset the AutoCAD profile to default (>>>details<<<).
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
I've done what you suggested first but the issue came back.
So, I've reset autocad to default yesterday but I have a plug-in I had to reinstall. It's called VBexpress and it's for reinforced concrete design.
0 Me gusta
Alfred.NESWADBA
Did it work then (before reinstalling the plugin?
- alfred -
Alfred NESWADBA
0 Me gusta
