Autocad does not run on my laptop ( STOP CODE "VIDEO_TDR_FAILURE")
No aplicable
I have an issue running AutoCAD on my laptop. I downloaded and installed any of previous version (2017,18,19), but every time I start using it is giving me the error Stop code: "VIDEO_TDR_FAILURE" and my laptop restart again.
I took my laptop to Microsoft IT department and they told me to contact Autodesk team as they say that the laptop is fine to run AutoCAD.
Vincent Rutahintare
0 Me gusta
Responder
1.512 Vistas
9 Respuestas
Respuestas (9)
DarrenP
don’t why microsoft told you its a autodesk problem
if you look up this error on the internet it points to a graphics card problem or driver
https://www.thewindowsclub.com/video_tdr_failure
DarrenP
0 Me gusta
pendean
Community Legend
Community Legend
No one here is Autodesk.
Your laptop make/model and specs are...?
Your Windows OS version is...?
The video card in the laptop is...?
Have you tried any of the posted solutions on he web yet https://www.google.com/search?q=error+Stop+code%3A+%22VIDEO_TDR_FAILURE%22
0 Me gusta
john.vellek
Hi @Anonymous,
This error is thrown when a graphics system is not responding.  Try uninstalling the current driver and using the last one or even the default driver that came with your system.  You can then upgrade it incrementally to newer versions as appropriate.
John Vellek
0 Me gusta
No aplicable
Dell XPS 15 Touch Laptop: i5-7300HQ,15.6" 4K, 8GB DDR4, 256GB SSD
That is my laptop specs
0 Me gusta
DarrenP
have you tried contacting dell about this problem?
this issue is not related to Autodesk software its a hardware problem
DarrenP
0 Me gusta
No aplicable
I try every solution they suggested,
( deinstall& install graphich) ,but still Autocad does not run on my laptop.
Here is my laptop specs :
Do you think this laptop is not compatible with autocad?
0 Me gusta
No aplicable
I took my laptop to microsoft technicians and they this is autodesk issue.
As it is only autocad which can not work on the laptop.
O
0 Me gusta
No aplicable
And what do you think about these specification:
That is my laptop and I think it is able to handle autocad.
0 Me gusta
No aplicable
again this is not an Autodesk issue
did you look up this error message on the internet?
where does it say this is caused by Autodesk software?
this is a hardware problem nothing more not Autocad
get in touch with dell ASAP & have them fix this issue
0 Me gusta
