Autocad Dimension problem? same style setting, but different sizes.
When I try to dimension, it's showing different size; top and bottom have exactly same setting. For the top one, I worked in other computer and when I try to work at home, it's showing different size. How do I fix this issue?
NVM. I fixed the issue. The scale was 1/8" = 1' and I changed to 1/4" = 1' scale, which is correct measurement.
scot-65
Looks like a dimension style override has been applied - DIMSCALE.
After creating the suspect object, command LIST and investigate.
To remove all current overrides for yet-to-be-new objects,
command "-DIMSTYLE" "Restore" (getvar 'DIMSTYLE)
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
