Anuncios
AutoCad Dimension Mask Background not Functioning
anjes_f
anjes_f
<AutoCad version 2020>
Kindly refer to attachment.
Would like to apply the background mask for the dimension, tried at properties palette and also text formatting. But it seems the function has been locked - cannot click at all at properties palette, and also not shown in text formatting field. This issue never happened before!
Appreciate for any help.
Many thanks!
0 Me gusta
Responder
Soluciones aceptadas (1)
1.985 Vistas
8 Respuestas
Respuestas (8)
vinodkl
Please check your dimension style. command "D" enter.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
anjes_f
Hi Vinod,
The setting for the fill color is "None". Because not all dimension will be using the mask background.
0 Me gusta
vinodkl
Please share the drawing, so that we can help.
0 Me gusta
anjes_f
Attached the file here.
Thanks!
0 Me gusta
vinodkl
Solución aceptada
I have checked on my end and I am able to fill color for the dimension text. I tested it on both AutoCAD 2018 and AutoCAD 2020.
Try updating AutoCAD 2020 with latest update and see if that fixes the problem.
Tested in AutoCAD 2020Tested in AutoCAD 2020
0 Me gusta
anjes_f
Yes! It is working!
Thank you very much!!!
0 Me gusta
mgalicki
MY ISSUE IS IN THE TEXT FORMATTING BOX, MY "MASK TEST" IS GONE FROM THER DROP DOWN? ANY INFO ON THIS IS GREATLY APPRECIATED.
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
0 Me gusta
pendean
Community Legend
Community Legend
Mask Text? Can you show us where you are looking please ( a screenshot or two) and for which "text" type as listed in PROPERTIES command?
0 Me gusta
