Autocad Data Extraction
Message 1 of 11
LIST lists coordinates in UCS. OK. But, Data Extraction lists coordinates in WCS. Why? Every user needs calulations with coordinates in UCS not WCS. Pls Help. English answer pls.
Accepted solutions (4)
Replies (10)
Message 2 of 11
imadHabash
Hi and Welcome to AutoCAD Forum,
>> LIST lists coordinates in UCS. OK. But, Data Extraction lists coordinates in WCS. Why?  <<
would you please attache here your list values and data extraction values as an images and attache the cad dwg sample ?
Imad Habash
Message 3 of 11
Alfred.NESWADBA
Because world coordinates is a constant base, a known base and so everyone knows the coordinates your extracted data is valid for.
I can only speak for myself (and a lot of people I'm working with), we only need geodatic coordinates and so based on WCS, we would hate it if we had a UCS activated and get then the coords in some temporary UCS ... and if so we would need to know with which UCS we had created each extraction data file.
May I ask when you need UCS coords?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 11
1) Please, see attached Files.
2) I can not select nor delete the Cyan Dashed Lines over the Ellipses. Pls, how i can do that?
Thanks, very much
Message 5 of 11
I need data for manipulation and construction, not in WCS, in UCS. I can not construct with WCS !. Thanks
Message 6 of 11
pendean
Community Legend
Community Legend
2. Your "cyan dashed lines" are a hatch pattern with a base point far below them
Message 7 of 11
Thanks for your instantaneously reply. OK. But, how to select/delet them?.
Message 8 of 11
imadHabash
if you don't mind .... i would like to draw your attention that your beautiful drawing have no new layers !!!! you're just work with colors and this is too bad. believe me (please) put your dwg elements on layers and start arrange them.
Imad Habash
Message 9 of 11
imadHabash
>> how to select/delet them?. <<
as attached below image just select them (see blue selected rectangle )
Imad Habash
Message 10 of 11
I understand. Thanks for your beatiful answer. Thanks, very much.
Message 11 of 11
Thanks, very very much.
