AutoCAD - Cut/Split an object by using line object..
driton.racaj
driton.racaj
Community Visitor
Community Visitor
Hello friends,
I'm kinda new in Autocad and I was wondering if there is any chance to use line to cut/split objects (ex. rectangle)?
Thank you,
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Ray-Sync
Puedes cortar usando la función Break at Point
Pirmero pones click en el comando y luego presionas click en las intersecciones.
jefferson
imadHabash
Hi and Welcome to AutoCAD Forum,
Since you're working with 2d object,Click on below image to see how by TRIM command you will cut the rectangle by using a line.
Imad Habash
j.palmeL29YX
If you want to stay the closed shape as a closed shape, here another possibility to get it.
Jürgen Palme
Kent1Cooper
[There is some ambiguity about your desired result, as you can see from the different replies.]
Another possible end result:  If you want to have the areas on both sides of the Line as closed objects, you can use BOUNDARY or BPOLY and pick inside each area.
The grip-editing approach [if that gets the desired end result] can be done in one fewer steps, by Adding one vertex and simply Moving another, rather than Adding two and then Removing the one in between.
Kent Cooper, AIA
SEANT61
Undoubtedly outside the scope of the OP’s request, but this linked thread introduces and automated (VBA) routine to speed up the process of slicing closed Polylines and Regions.
https://forums.autodesk.com/t5/vba/divide-a-region-into-several-regions/m-p/1861065#M79800
I’m mainly posting it here to enjoy a bit of nostalgia – self-serving as it may be.
That old VBA code does still work up to AutoCAD 2016, at least, and may work beyond that.  Regardless of its compatibility, though, there will be upfront effort to set the VBA environment, as well as some CUI work to get the routine more user-friendly.
https://knowledge.autodesk.com/community/screencast/44bceac2-783b-4ea3-9e57-f4dc4038b211
May your cursor always snap to the location intended.
handjonathan
Hi @driton.racaj
Thanks a lot for posting your question to the forums!   Has the solutions suggested by @SEANT61 @Kent1Cooper @j.palmeL29YX @j.palmeL29YX @ helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
