AutoCAD cursor lagging/jumping, not smooth
No aplicable
I have Autodesk AutoCAD 2017, windows 7, Intel Core i7, 16G 64-bit.
My cursor has been delaying. I have done the updates and restarted the computer. I am currently using NVIDIA Quadro 4000M. My hardware acceleration is currently ON. I have turned it off and still does not fix the issue.
Any solution?? Please!!
0 Me gusta
Responder
Soluciones aceptadas (1)
1.810 Vistas
5 Respuestas
Respuestas (5)
imadHabash
any changes if you press F9 (snap off) .
Imad Habash
No aplicable
No solution. I also purged and audited the file. No luck there either.
0 Me gusta
imadHabash
does this happened in a certain CAD file or in every file even new one?
Imad Habash
0 Me gusta
john.vellek
Hi @Anonymous,
I too am curious if this is happening in only one file or all your files.  F9 is a good first step. The next I would suggest is to see if you have object snaps trying to snap to things - I suggest turning them all off.
If this is happening in just one file, is it one you can share or send to me at john.vellek@autodesk.com if it needs to be private?
John Vellek
0 Me gusta
No aplicable
Solución aceptada
Yes it was the file. I moved it into a new file and that solved the problem. Simple fix, thanks!
0 Me gusta
