AutoCAD cursor and object snap moves slow when using any function
Message 1 of 8
When I use any function in my AutoCAD drawing regardless of the size, my cursor moves slow and gets jumpy. When I just move through the drawing, it moves smooth and uninterrupted, but once I select even the dimention function, my cursor takes several seconds to move from point to point and even trying to select an end point of a line takes 3 seconds or more. I don't have snap mode on and I have already went through GRAPHICSCONFIG which made no difference. I read about an accelerator value and mine is set at -2 currently. I have 8G ram and an i7 processor. I am wondering if there is another setting I am missing that is causing this major slowdown when I try to use any command.
Thank you,
Replies (7)
Message 2 of 8
S.Faris
If your DYNAMIC INPUT is ON Turn it OFF (Press F12). I believe what you explained is for any DWG file and not just in a particular file.
SALMANUL FARIS
Message 3 of 8
My Dynamic input was already turned off. Turning it on did not make a difference either.
Message 4 of 8
pendean
Community Legend
Community Legend
restart your PC.
Start AutoCAD, open a new blank file, draw a dozen things: can you repeat the problem?
Message 5 of 8
mike.pool
From the AutoCAD command line, try turning off TRANSPARENCYDISPLAY (setting to "0").  There is also an icon toggle for this on the AutoCAD status bar (looks like a checkerboard).  If it doesn't show on the status bar, you can turn the toggle on using the 3-bar icon at the far right.
Transparency toggleTransparency toggle
Message 6 of 8
The problem was not repeatable on the new drawing file
Message 7 of 8
pendean
Community Legend
Community Legend
INSERT your problem file into this no-problems new file, EXPLODE, test, if the problem goes away then SAVEAS, create a new file, work with it and enjoy the rest of your work day.
If the problem is still there post that DWG file here for others to examine.
Message 8 of 8
This seemed to help speed it up. Thank you!
