AutoCAD crashes when using MIRROR command
Neil.dixon
Observer
Neil.dixon
Observer
Observer
Hi, using MIRROR command on a complex 3D model, I applied the mirror command successfully but realised I'd made a mistake, I undid the mirror command. Then when I reapplied mirror AutoCAD stopped responding. I have recreated this crash a few times. I checked system resources, I'm only running at about 50% of my resources, but AutoCAD is using 100% of a single core, after AutoCAD stops responding it keeps alternating between different cores.
Not sure if this is my hardware reaching it's limits or a bug in AutoCAD. Any advice will very much appreciated. Thanks.
0 Me gusta
Responder
1.315 Vistas
5 Respuestas
Respuestas (5)
pendean
Community Legend
Community Legend
>>>...on a complex 3D model...<<<
Do it again, but this time QSAVE after you UNDO. See if that helps.
Otherwise see if you problem DWG file (and all attached XREFs) needs repair.
0 Me gusta
No aplicable
Few things you can try. Do an audit and a -purge and remove all regapps. Save the drawing and try again. Also you can try to turn your hardware accelerator off.
Neil.dixon
Observer
Observer
hi, thanks for the suggestion, I tried QSAVE, but this had the same effect and AutoCAD crashed in the same way. I tried the same .DWG file on another computer and the recreated the same crash in the same way. So I guess it is a problem with the file. Not sure how to fix the file, but when I did Audit, nothing came up.
thanks again
0 Me gusta
Neil.dixon
Observer
Observer
Thanks, I tried audit and purge. Audit found no problems and I removed a few regapps, but I still have the same issue.  I tried turning off hardware acceleration as well, same issue. I think it might be a problem with the file because I get the same issue with the same file on a different computer, although nothing came up on audit. Not sure if there is a way of fixing the file. Thanks again for you help.
0 Me gusta
pendean
Community Legend
Community Legend
0 Me gusta
