Autocad crashes when using attribute command
No aplicable
When I am clicking insert field in the attribute command autocad suddenly crashes with the error screen,
I attached the error screenshot with this post.please find the attachement
give me a solution as soon as possible
thank you have a great day
0 Me gusta
Responder
455 Vistas
7 Respuestas
Respuestas (7)
Alfred.NESWADBA
Does the file exist on your system?
Which version of AutoCAD and which service pack are you running ... on which operating system?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
No aplicable
hi @Alfred.NESWADBA
Autocad 2018 running on win 7 64 bit SP1
it crashes not only a particular file.
0 Me gusta
Alfred.NESWADBA
>> Autocad 2018
Which service pack? Start command _ABOUT and show as a screenshot from that dialog.
If it's specific to one file then run command _AUDIT or _RECOVER to find/repair errors in the drawing database (if there are any).
Or run command _WBLOCK with option "Entire drawing" ... then start with the new drawing created now and see if the issue is the same.
If nothing helps then you might upload the file so we can test it on our systems ... and please describe step-by-step what exactly need to be done to make AutoCAD crashing.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Try Reinstalling your AutoCAD.
I think AcFdeval.crx is not located in your installed folder or It has a problem.
0 Me gusta
No aplicable
Hi @Anonymous
the file AcFdeval.crx is there in the installed folder but the error message shows that it was not located .
What is the solution in this case?
0 Me gusta
Alfred.NESWADBA
Have you seen post 4 in this thread?
- alfred -
Alfred NESWADBA
0 Me gusta
john.vellek
Hi @Anonymous,
Can you please detail what your system looks like?
OS version
AutoCAD Version (and updates/hotfixes installed)
Graphics card make and model
Has AutoCAD just started this behavior or is this a new install? If it just started can you tell me what might have changed in your environment?
Have you checked to see if there is a more current graphics driver?
John Vellek
0 Me gusta
