Recently installed Autocad 2018 LT. In the 2012 LT, I bound my mouse 4 button to the Copy Command with no issues by making my Mouse 4 button hit F11 (in logitech settings) and binding F11 to copy (in autocad shortcut keys settings).
In the previous 2012 version I was able to select an object, press mouse 4 to copy, then select base point then copy to wherever.
In the 2018 version, I select the object, press mouse 4 to copy, and it deselects the object and then starts the copy command. I then have to reselect the object.
How do I fix this? Pickadd is 2, Pickfirst is 1. It appears to only be an issue with the keyboard shortcut itself. I can type the command and it works as usual.
I've noticed when I press Mouse 4 it initiates the command and when I let go it cancels. It works if I hold the mouse 4 button down as I copy.
I've even reset my autocad settings and set the binds from scratch and it still does this....
I've even bound my mouse 5 to match properties and this works perfectly find, it is only the copy command/mouse 4 button
