AutoCAD - Converting drawing units or dimension display to feet show incorrect value by factor of 1/12
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Thank you in advance for reading/helping, I’m super stuck.
The issue( see attached photo): i.e. the dimension length showing "900.00[decimal unitless units] displays the correct value, BUT is supposed to be 900 FEET. If you display the dimension in [architectural or engineering feet-inches] format, it divides the value by 12 and shows the incorrect value of 75' for that same line.
I need help with solving this scaling issue. I am using the geolocation map within the AutoCAD software (originally set with AutoCAD Map 3D, CA State Plane Coordinates in Survey Feet). I’m using the internal map/capture region as a background to my plans/vicinity map. I need to make sure that I can show proper, accurate dimensions when I draw/measure on top of that map.
..I need to show dimensions in [FEET'-INCHES"] format.
In my photos, the red represents the length in [FEET'-INCHES"] dimension style, ARCHITECTURAL.
The green dimension shows [STANDARD} dimension style, DECIMAL (unitless unit).
[ The subject line of this post has been edited for clarity by @handjonathan Original: Help with Scaling Issue in Autocad/Map 3D:Drawing Decimal Unit Shows Correct number in Feet, but Converting drawing units or dimension display to feet show incorrect value by factor of 1/12 ]
