Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Forum
Autocad color changes in drawing into another
5 REPLIES 5
arunag
596 Views, 5 Replies
Dear experts,
Autocad on my computer is showing different colors on drawing area and on properties or layer manager.
If cyan is chosen in layer properties, by layer followed, it displays yellow in drawing.
All colors are different, shows correctly in properties or layer manager, but draws different color on model space. What could be the reason. Please help.
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
5 REPLIES 5
Alfred.NESWADBA
in reply to: arunag
which version of AutoCAD (command _ABOUT) and which graphic card (command _GRAPHICSCONFIG)
Also please try with command _GRAPHICSCONFIG to turn off hardware acceleration ... better?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
vinodkl
in reply to: arunag
select all (ctrl+a) and use the command "SETBYLAYER" to set the color of the object as per the layer.
If this doesn't solve your problem please post a screenshot or attach the drawing so that we can help.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
in reply to: arunag
i'm afraid that your drawing elements are NOT bylayer colored !!! you may need to check that ? can we have A CAD drawing sample please ?
Imad Habash
arunag
in reply to: Alfred.NESWADBA
Yes it worked after acceleration got off. Thanks.
Aruna
Bangalore
Alfred.NESWADBA
in reply to: arunag
In that case you either need updating AutoCAD and/or the graphic card driver (that's why I was asking for details about AutoCAD version and graphic card information).
But good to know we found the source of the issue!
- alfred -
Alfred NESWADBA
AutoCAD Inside the Factory
