AutoCAD Clip Options
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi all
I am looking for the best way to achieve the following using the clip command.
What I want to do is isolate one steel floor level in a building by clipping say 1 metre above and 1 metre below that level and then viewing the result in plan. That way I can work on trimming steel at that level without worrying about picking up intersect or end points above or below the plane of the floor steel.
In AutoCAD Structural detailing there is a clip command which allows the UCS to be located at the floor level required and then front and back clipping planes can be added above and below that datum. However that software is now discontinued (shame on you AutoDesk).
Anyone tell me the best way to repeat this operation in vanilla AutoCAD please?
Phil
