>> I think 2nd message is the cause why file is not opening. somethings is
>> wrong with the file I believe.
From what I see in your second post:
If the file was created with AutoCAD 2011 then you should be able to open it with your Civil 3D 2018
Also the file header starting with "AC1032" points to a filetype you should be able to open with your Civil 3D 2018
So what happens now when you open that file with Civil 3D 2018?
If you get the message "incompatible version" (according to your screenshot in the first post) ... then I guess you don't have Civil 3D 2018 ==> please start your type of AutoCAD, start command _ABOUT and show us a screenshot from that dialog
If you get the message that SHX files are missing, then you might see wrong fonts, maybe some characters are missing in your text-like objects, you might see incorrect linetypes .. but the drawing should be loaded and visible!
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
