Anuncios
AutoCAD - Change multiline text cursor colour
tammmy
tammmy
Where can I modify multiline text cursor colour?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Multiline text cursor colour ]
Responder
2.131 Vistas
7 Respuestas
Respuestas (7)
jayhar
Not in multiline text cursor. it can change cursor colour.
Solution: in AutoCAD follow you do those. You can change cursor’s color, size very easy so that according with your wish. Option command will help you do those as following: The default cursor’s color is white. Access option dialog box, click display > color > 2D model space > crosshair > choose color anything.
Below Tick Tint X,Y,Z for multi color
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
0 Me gusta
tammmy
I would like to modify cursor colour in the text editor!
0 Me gusta
Patchy
It's controlled by Windows not Autocad.
Change the background color of the drawing and windows choose its own color for the cursor.
0 Me gusta
softwareSMHQ7
Observer
Observer
I have the same issue as Tammy, as so I tried a number of things along the lines of what you suggest about windows controlling the cursor.  And none had any effect.  See the first SS where I show some of the exaggerated the color and the thickness of the, then look at the second SS and note that it is a where's Waldo to even see the cursor in the text editor.  And just to show that the Settings took, look at the last SS where I then went to do a save file.  So AutoCAD blocks the ability of Windows to change the Cursor features.  I also did a number of combinations of the Widows settings with features on and off and the AutoCAD Cursor is unchanged.  And I have also looked into changing background colors and the cursor remains grey in all cases.  AutoCAD has to have some place where they control this cursor, just where that is, is yet to be determined.  I started using AutoCAD with version 2.X in the 80's and I have been able to solve almost every issue or find a work around except this one.  I will likely be retired before I find a solution.
0 Me gusta
ВeekeeCZ
Do I understand correctly that you have an issue with a white-colored cursor when the mtext background mask is of color that does not contrast enough to the white?
0 Me gusta
tammmy
Yes!
0 Me gusta
ВeekeeCZ
Great!!
If I had any follow-up suggestions in mind, I don't really remember them.
0 Me gusta
