All,
I would appreciate some help in trying to make an AutoCAD block smaller without exploding. The current block was provided by a Client and I am unable to contact them to provide an exploded version.
The current block has over 5 million lines, and when I explode the block my computer crashes (computer is relatively high spec (Intel Core I7 2.7GHz & 32GB RAM)). I have been able to 'Edit block in-place' and then 'prompt to select nested objects' and this allows me to select small sections and delete as needed, but this process is too slow and only allows me to delete approx. 300 lines at a time.
My ultimate aim is to delete all the unnecessary information and reduce the block size considerably (by 90%) to make it easier to use. I just need a useful command to be able to select large sections and delete without exploding. Any input you can provide would be greatly appreciated.
