Anuncios
AutoCAD Block interaction
No aplicable
I work for a retail design studio. I am all the time inserting refrigerated cases of varies lengths (4', 6', 8', 10', etc). I would like to create a lisp routine or a block that is interactive with a user prompt. So if I want to insert a 12' Refrigerated Case, then once I select the LISP routine, it will prompt me for a length. Once I type in 12’, it will reference the block with a 12’ Refrigerated Case.
0 Me gusta
Responder
Soluciones aceptadas (2)
359 Vistas
2 Respuestas
Respuestas (2)
imadHabash
Solución aceptada
Hi and Welcome to AutoDesk Forum,
DYNAMIC BLOCK indeed is your need,you can mange it in a very charming way.if do you want to know about it type Ctrl+3  then go to Structural tab insert the first WF Beam then select it and go for the blue arrow..
Hope it's help....
Imad Habash
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
Here is a sample dynamic block that includes 4', 6', 8', 10', and 12' foot refr. cases (shown as a rectangle). If you click on the block you will see a drop-down arrow that allows you to select the block size you want. Each set of geometry is contained in its own Visiblity State.
Will this work for you? If so, I can help you understand how to modify the geometry or display to meet your specifics.
John Vellek
0 Me gusta
