Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hello!!
Is there another command I can use to smooth that edge other than command fillet?
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
If fillet is not giving you the shape you want, have you considered building another solid so you can subtract its profile from the model?
Can you share your model or sample and give me an idea of the type of edge you want to produce? I am to explore this for you.
