AutoCAD Forum
AutoCAD 3D - Smoothing Edges
3 REPLIES 3
2689 Views, 3 Replies
Hello!!
Is there another command I can use to smooth that edge other than command fillet?
3 REPLIES 3
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
If fillet is not giving you the shape you want, have you considered building another solid so you can subtract its profile from the model?
Can you share your model or sample and give me an idea of the type of edge you want to produce? I am to explore this for you.
John Vellek
in reply to: john.vellek
Subtract command worked! Thank you.
hlokesh
In engine model disc not shown in circular shape, can you please give solution on this?
AutoCAD Inside the Factory
