Autocad 32-bit files won't open on a 64-bit computer
Message 1 of 8
I recently setup a new desktop that is 64 bit win7 os. His old computer was 32-bit. We have reinstalled his autocad but when we open the old drawing it won't open since they were saved as 32-bit. The only solution I have found from searching is the longbow converter but this costs about 300 dollars. I was hoping that someone might have a few suggestions.
Replies (7)
Message 2 of 8
rkmcswain
Never heard of this. There is no difference in the data files created with x86 AutoCAD vs. x64 AutoCAD. What is the exact error message? Screenshots?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 8
Thank you for the reply I will get the user to send me a screenshot.
Message 4 of 8
Here you go.
Message 5 of 8
rkmcswain
So did you install 32-bit AutoCAD on the Win7x64?
If so, what version?
If you google that file name ( Acismobj15.dbx ) there are a lot of results of people trying to run older x86 versions of AutoCAD on Win7x64.
Message 6 of 8
He installed the 64 bit version of 2002.
I'm going to double check.
Message 7 of 8
rkmcswain
Pretty sure there was no x64 version of AutoCAD 2002, so if this is AutoCAD 2002, then this seems to be a common issue. You may be able to find a hack/workaround but you might want to consider obtaining a newer version of CAD software that will install and run on Win7x64.
Message 8 of 8
pendean
Community Legend
Community Legend
Your client probably needs to pay these folks to get their old 32bit product to run old software on newer 64bit WIndows versions http://www.longbowsoftware.com
