autocad 2106 xref Notification
steveblurton8276
steveblurton8276
Hi. I am having a problem with Autocad 2016 and the xref notification.
When an xref that i have in my drawing is amended and saved by another user i get a balloon notification to say that it needs reloading. However, when i open a drawing where there were xrefs previously but have been moved or renamed i only know about it if i read the command line while the drawing loads. I don't get a box coming up anymore that says its cant locate an xref and do i want to update the location or ignore.
I have looked through the forums and made sure that xrefnotify is set to 2.
Is there another variable or have i  (or someone else) done something to the set of drawings to prevent the pop up?
Responder
Soluciones aceptadas (1)
1.126 Vistas
3 Respuestas
Respuestas (3)
rkmcswain
Solución aceptada
Do you mean that you do not get this dialog when opening a drawing with missing xrefs?
If so, then go to Options > System Tab > General Options > Hidden Messages Settings
Then check the appropriate box, and press OK.
The next time you open a drawing with a missing reference file, you should get the first dialog above, again.
imadHabash
follow this >> Link << i hope it's help.
Imad Habash
TheCADnoob
0 Me gusta
