AutoCAD 2025 - Purge All Button Doesn't Gray Out
BillAllenSE
BillAllenSE
Is it just me or is this a problem? When I click on "purge all", the button doesn't gray out. Yes, I've checked every check box. Yes, I know there are some non-purgeable entities. It's just that, when I've done this in ACAD 2024, it would gray out when I perform a similar operation.
TIA
Responder
Soluciones aceptadas (1)
641 Vistas
4 Respuestas
Respuestas (4)
pendean
Community Legend
Community Legend
You'll need to report that to Autodesk yourself: nothing for end users to fix as far as I can tell.
Here is how to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
0 Me gusta
BillAllenSE
Thank you, pendean.
I've submitted a support case and I will report back when I get a response.
0 Me gusta
BillAllenSE
Solución aceptada
Autodesk says the developers are working on this issue. The current workaround is to leave the Orphaned Data box unchecked.
pendean
Community Legend
Community Legend
Thanks for the workaround
0 Me gusta
