Autocad 2025 DimCONTINUE weird undo behavour
nam_h_tran
nam_h_tran
(view in My Videos)
With this command, i can continue my dimension. But 1 problems with undo that i feel really weird. These are the step:
1: using dim continue to continue dim
2: draw some dim
3: choose select option and select another dim
4: draw some dim
5: undo.
Now keep undo and it will undo till the last object of the previous dim and it will change to prompt: select dim
6: select dim
7: draw some
8: undo
It will having same behaviour above.
Why can't just undo everything but i need to keep select another dim, then keep undo to undo all the dim i draw in frist dim.
here a videos for it.
pendean
Community Legend
Community Legend
One solution: UNDO command has options and set points you can activate: consider fully using the command's abilities instead of relying of uncontrolled-by-you default behavior.
Don't forget about REDO and OOPS command too.
Here is an easy tip to remember: use QSAVE to set undo stopping points.
