Anuncios
AutoCAD 2025 Data Extraction not exporting Position x,y,z as in older versions
i.Almohsen
Observer
i.Almohsen
Observer
Observer
Hi everybody,
I used to export my survey plan in Data Extraction in AutoCAD 2022 and get the X, Y, and Z positions as a CSV file.
I recently updated to AutoCAD 2025, and this option is no longer available, as you can see in the picture below.
(Sorry it's in german).
I can still export the position values, but they are all in one field instead of being separated.
Does anyone know why this is happening or if anyone else is experiencing the same issue?
Thank you! :cara_con_una_leve_sonrisa:
0 Me gusta
Responder
228 Vistas
2 Respuestas
Respuestas (2)
Pointdump
Hi Ihsan,
Thanks for posting your drawing.
Your Block References Z elevation doesn't match the text, but I had no problem harvesting X,Y,and Z. (I'm using Civil 3D 2025)
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
i.Almohsen
Observer
Observer
Hi Dave,
Thank you for your response.
It looks like an AutoCAD issue. I tried using Civil 3D 2025, and it worked.
