AutoCAD 2023 - DWG from fusion in inches
CHAY.HOBSON
CHAY.HOBSON
When I import my DWG I have exported from fusion into Autocad changes the units to inches. E.g one of the holes is 8mm in fusion it becomes .8inch in Autocad. I am in the uk. I am using autocad 2023 education as I teach in a college.
I have tried changing the drawing units DWGUNITS and the UNITS but neither has fixed the problem. The hole scales from .8inch to 20.32!! Any help would be great.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
0 Me gusta
Responder
384 Vistas
5 Respuestas
Respuestas (5)
imadHabash
You may need to check INSUNITS (System Variable) before inserting the drawing.
Imad Habash
pendean
Community Legend
Community Legend
DWGUNITS command inside your DWG file in AutoCAD lists what as the unit of your DWG file?
and, in UNITS command what do you have set for units in that same DWG file?
You never say. and changing them after you inserted the source file later on is never the best way to do it.
0 Me gusta
CHAY.HOBSON
I have tried changing the units before inserting the drawing. I have changed them in options but it seems to revert straight back to inches.
0 Me gusta
pendean
Community Legend
Community Legend
Can you share all those files here? I don't use Fusion but maybe some here can double-check that too for you.
0 Me gusta
leeminardi
In my opinion, the way AutoCAD deals with units is at best awkward.  First off, the word “units” is misused in AutoCAD.  Here’s a definition of units:
   a quantity chosen as a standard in terms of which other quantities may be expressed.
Angstroms, millimeters, inches, feet, meters, smoots, kilometers, miles, and parsecs are all examples of units for length or distance.  The words from the UNITS command including  “decimal”, “architectural” and “engineering” are examples of formats for representing a number.  AutoCAD occasionally refers to these as Length Type.
As many have noted, AutoCAD is dimensionless.  When you create something at a coordinate of say 1.23, its location is in AutoCAD units.  You, the user, may be assuming that 1.23 represents inches but someone else may be assuming centimeters when they enter a coordinate of 1.23.
The UNITS command does not set which units are being used.  There is no way in AutoCAD to set units! Reading the fine print in the Drawing Units dialog box it says “Units to scale inserted content.”
The UNITS commands sets the scale factor that will be applied when inserting a drawing into the current drawing.  It does not “set units”. If you assumed that inches were the units you were working with and the creator of the drawing you are inserting assumed centimeters then by specifying centimeters with the UNITS command prior to inserting the drawing it will automatically be scaled 2.54 upon insertion.
The units scenario gets even more interesting when it comes to plotting the drawing.  The paper size specified will affect the scale of the plot!  For example, suppose we have a drawing with a circle of diameter 12 (AutoCAD units) and within it a square of 6 units per side.  With the paper size set to ANSI A (8.5 in. x 11.5 in.) as follows:
The plot would look like this:
Relative to the 8.5 x 11 inch paper the 6 inch square looks the correct size.
However, changing the paper size to ISO A3 (420mm x 297mm or 16.535 in. x 11.69in) and plotting full size yields the following!
AutoCAD assumed that since you are using a metric sized paper then you must have assumed the metric units of mm when creating the drawing!  This is done even though AutoCAD does not store the assumed units with a drawing. The plotted drawing is thus scaled down by 25.4 and instead of a 6 inch square you get a 6/25.4, or 0.236… inch square on your A3 piece of paper.
Bottom line.  If you want to assume you will be entering values in inches then go ahead.   Changing the units style to architectural will show a distance of 18.0 as 1’ 6”.   For your drawing that is showing (as I understand it) 20.32 instead of 0.8 just scale the entire drawing by 25.4  ( 25.4 mm = 1 inch) about a base point of 0,0,0.
lee.minardi
0 Me gusta
