AutoCAD 2023 - Cursor disappears when selecting objects
vigitha2001
Message 1 of 12
vigitha2001
I exported a drawing I did on my previous laptop (which was really slow).
So I bought a new laptop with a better GPU: NVIDIA GeForce RTX 3060.
But when I work on this project, for example when I select an object with my mouse, my cursor disappears and doesn't come back.
I don't understand why, can you please help me with that?
Replies (11)
Message 2 of 12
paullimapa
See if problem disappears when you disable hardware acceleration
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-e...
Paul Li
IT Specialist
@The Office
Message 3 of 12
vigitha2001
No unfortunately I tried almost every solution here:  https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Mouse-...
And nothing worked..
Message 4 of 12
paullimapa
so this problem only happens on this project and not with any other drawings you work on?
Paul Li
IT Specialist
@The Office
Message 5 of 12
braudpat
Hello
Command :   GFXDX12   < Entree >          0   < Entree >
Quit ACAD 2023/2022 - Relaunch ACAD  ...  Now ?
Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 6 of 12
vigitha2001
Yes, I think so
Because I tried it with the desktop computer of my relative (with NVIDIA GeForce RTX 3070)
Message 7 of 12
braudpat
Hello @vigitha2001
Please your driver has to be >= november 2022 !?
Version : R525 U2 (527.27)  --  Date: 2022.11.28  --  ??
Bye, Patrice
Patrice BRAUD
Message 8 of 12
vigitha2001
Yes as I told earlier I did every step mentionned in the following link : https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Mouse-...
And updating the drivers is one of them.
I have the latest version : 528.49 (2023.02.08)
Message 9 of 12
vigitha2001
Nobody can help ? 😞
Message 10 of 12
pendean
Community Legend
Community Legend
@vigitha2001 wrote:
Nobody can help ? 😞
Have you installed the 2023.1.2 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort, and start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~...
Message 11 of 12
vinodkl
Hello @vigitha2001
Try moving the mouse cursor over the Viewport Controls in the upper-left corner of the drawing window. Does the cursor reappear now?
If this doesn't work then the only option would be to reset the AutoCAD to default. Hope that helps 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 12 of 12
vigitha2001
Unfortunately, none of your suggestions helped... Thank you anyway..
