AutoCAD Forum
AutoCAD 2023 - Block attributes burst
6 REPLIES 6
autoskocc
555 Views, 6 Replies
Just a quick one. Is there a way to burst a block so the text attribute is separated from the symbol as it normally is using that command but the symbol is not being exploded. I'm using the newest version of AutoCAD.
Regards
[ The subject line of this post has been edited to include the product name by @handjonathan ]
6 REPLIES 6
RobDraw
in reply to: autoskocc
The block needs to be made with that objective in mind. A nested block should do the trick.
Rob
autoskocc
Good point, thank you.
imadHabash
There is NO direct way for that .. Sorry !
Imad Habash
autoskocc
in reply to: imadHabash
What's the undirect way?
autoskocc
Hi guys, I'm back to the project and unfortunately cant do nested blocks . The software I'm using with AutoCAD doesn't recognize them and spits out normal blocks instead of nested. Is there another way to do that?
Kent1Cooper
BURST, like EXPLODE, leaves the pieces of what it broke up as the Previous selection set.  Are these Blocks that are Inserted multiple times, or only once?  If they're one-off instances, a routine could be made to take that Previous selection set after BURSTing, remove the Text element(s?) from it, and redefine the Block using the remaining pieces.
Kent Cooper, AIA
Forma Design Contest
