AutoCAD 2022 - Zoom Window Lockup
RDuffell
RDuffell
I am noticing that while in the command of moving an object, if you try to zoom in, AutoCAD locks and will not respond until you hit esc. My AutoCAD 2021 (still installed) does not do this.  I can zoom previous, just not zoom window.
I have reverted to using 2021 as this command within command is critical for what I do all day long.
Replies (13)
pendean
Community Legend
Community Legend
R2022 is not R2021.
Did you trying turning off LINEFADING and LINESMOOTHING variables to see if that helps?
Post a screenshot of your GRAPHICSCONFIG command pop-up from R2022, lets see what is running on your PC. You may need to turn off hardware acceleration too.
8XXXNNJH7KT6
If you pick twice (i.e. the two points for the zoom window) while it appears to be hung up, does it then continue? Another check would be if you move the mouse down or up, does the cursor appear when the mouse gets outside of the drawing window such as when it gets over the command line or over the ribbon? If so, then the problem is that the cursor and zoom window are not showing.
Alfred.NESWADBA
this is a new issue with 2022, reproducible ... run these steps:
  • start command _LINE
  • pick first point
  • then using keyboard: 'ZOOM<ENTER>
  • now you can move the mouse inside the graphic area, but the cursor is not following these moves. The coordinates in the status bar are running/updated, however this does not really help if you want to use transparent zoom window to get more close to a point.
All this is not recognized from the people using the mouse wheel to zoom and pan, but for others used to use 'ZOOM to zoom window it's a stopper (and it's new in 2022). E.g. for people with tablet instead of mouse.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
whitech.chuck
Turning off LINEFADING (whatever that is!) worked for me.
Alfred.NESWADBA
Type in into the commandline
LINEFADING<ENTER>
<F1>
...and you'll see what this is 😉
- alfred -
Alfred NESWADBA
Linefading did not work.
Any other solutions?
Alfred.NESWADBA
For which issue, which AutoCAD version, which graphic card and driver?
Updating AutoCAD; updating graphic card driver, resetting the AutoCAD profile, uninstall plugins you use, check your drawings for errors (and referenced files); change mouse, change resolution of display(s), .... a lot of suggestions, but without knowing what exactly is happening and some information about your hardware/software I can't send "this one solution".
- alfred -
Alfred NESWADBA
pendean
Community Legend
Community Legend
@david.fuller  Have you installed the 2022.1 Update yet? If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT2022: reverting to DirectX11 fixes similar problems for most users.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort.
If still no relief you have a system level issue, consider engaging your IT folks.
AutoCad 2022
Not a problem with AutoCad 2021 or 2018
Running all the same hardware.
All the same settings.
Can open the drawings in anyother version and it works fine.
From post above
  • pick first point
  • then using keyboard or Zoom window button: 'ZOOM<ENTER>
  • the line locks up and you cannot see where you want to zoom. arrow and crosshairs gone. can see arrow outside of graphics window. The coordinates in the status bar are running/updated, however this does not really help if you want to use transparent zoom window to get more close to a point.
Solved with 2022.0.1 Update.
Alfred.NESWADBA
This description would have brought us to update 2022.0.1 as this was part of the repairs.
I hope you understand that the description is necessary to give valid suggestions (better than guesses all the day).
Anyway, good to know you have got it working. 😉
- alfred -
Alfred NESWADBA
whitech.chuck
Fixed with 2022.0.01 update.
chrisnUMXZV
Community Visitor
Community Visitor
I had the same issue, and installing the update alone did not work. I then turned off 'linefading'. I assume the combination of the two worked.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
