AutoCAD 2022 Unable to Open Multiple Files in Single Instance
joelmNKB6B
Message 1 of 9
joelmNKB6B
I am unable to open multiple .dwg files in a single AutoCAD instance. I'm using Windows 10. I've followed all instructions in the following article, except for the section "edit the windows registry":
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Double-clicking-a-...
Is there anything I should try before going down this route? I would prefer not to if I can help it.
Thanks in advance for any help!
Replies (8)
Message 2 of 9
paullimapa
If setting SDI to 0 still doesn’t let you open multiple drawings then you may want to try a reset
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC....
Paul Li
IT Specialist
@The Office
Message 3 of 9
pendean
Community Legend
Community Legend
@joelmNKB6B wrote:
I am unable to open multiple .dwg files in a single AutoCAD instance. I'm using Windows 10....
If I may ask, AutoCAD 2022 is not new (neither is WIn10): did this used to work for you nd now it just suddenly stopped?
Or did you just get a new PC or this is a first-time install, or you added a 3rd party tool or are using an OEM version of AutoCAD2022?
Or...?
Message 4 of 9
joelmNKB6B
I was trying to solve another problem (long pauses when inserting a block from a network drive) and this popped up. the only things I did before this popped up was:
Taskbar: 0 (was already at 0)
SDI: 0 (was already at 0)
Changed .dwg file association from DWGlaunder to AutoCAD.exe then back to DWGlauncher.
not sure how this broke AutoCAD
Thanks!
Message 5 of 9
pendean
Community Legend
Community Legend
Restart your PC please.
Message 6 of 9
joelmNKB6B
I have already restarted it multiple times, but will try it again - would an upgrade to AutoCAD 2023 be any help?
Message 7 of 9
paullimapa
So what happens in Autocad now when you have a drawing thats been changed in the current window and you enter the _.OPEN command?
Are you prompted to save the current drawing before the Select File window opens?
Paul Li
IT Specialist
@The Office
Message 8 of 9
pendean
Community Legend
Community Legend
@joelmNKB6B wrote:
...except for the section "edit the windows registry":
...I was trying to solve another problem (long pauses when inserting a block from a network drive) and this popped up...
TASKBAR =1 change anything?
At this stage you probably should be working with your IT person. Ask them to do the registry edit.
A Reset of 2022 would be something worth trying.
A removal and reinstall of 2022 then updating it may be something else to try.
Message 9 of 9
joelmNKB6B
I did an upgrade to 2024 and it fixed the problem, thanks everyone for your help!
