AutoCad 2022LT has been running very sluggishly for me even when in a simple CAD file. This is killing my workflow. I'm not super technical so any help in a simplified format would be greatly appreciated!
Solved by vinodkl. Go to Solution.
you can refer to these LINK and LINK and see if helps. thanks
Hi @Anonymous
Type in the command "3DCONFIG" and try turning ON the "Hardware acceleration". If its already turned ON, then type in the command "DYNMODE" and set it to "1".
Hi @Anonymous
