AutoCAD 2022 - Selecting viewports properties
mcweb
mcweb
This only happens with clipped (polygonal) viewports.
When I click to select the viewport and want to view or edit using the properties box, it shows that I have a polygon selected, and I have no viewport properties available. When I use a drag box to select the same viewport, it works properly and I can view and edit properties.
This has recently started happening on all of my drawings. I was wondering if this is a setting, or a problem in the files.
Windows 10
Autocad 2022.1.2
Thanks!
[ The subject line of this post has been edited for clarity by @handjonathan Original: Selecting viewports ]
Responder
Soluciones aceptadas (1)
404 Vistas
3 Respuestas
Respuestas (3)
cadffm
Solución aceptada
The Polyline (or cicle, or region..) is the Viewport clip-object (because a viewport object is always rectangle,
it is only possible to "VPCLIP" it.
Q: Check the SELECTIONCYCLING feature, is it ON on one machine and OFF on the other one?
Sebastian
paullimapa
see if it makes a difference by updated to 2022.1.3
Paul Li
IT Specialist
@The Office
mcweb
Thanks! @cadffm
SELECTIONCYCLING was set to 1. I set it to 0 and it works as before.
I never knew that clipped viewports were 2 objects!
